Greased the u joints TREs and other shat.
Heading to chinamin freight friday I need more expendables.
Is their any thing wrong with a Y link assumint its using a 5/8ths bolt instead of a 10mm? Like TNT Y link?
Ballistics got them.depends on how you build it.
you can do it, but if you are using the stock diameter UCA housings thay doesn't leave much rubber bushing to deflect after you add a sleeve in there and your flex will likely suffer.
I don't know where you are going to find a bushing to fit in that with such a large bolt either.
9/16s is more reasonable. Atleast I believe it is?
No.you mean you are going to chop off the factory uca bushings to run their forged bushings?
I can't help but ask why. everybody has been using the stock stuff with radius arms for about 15 years. No need to spend more money and overcomplicate things to achieve the same end result.
Ok Ill remember that.if you never wheel, you wont have to worry about these things.
Maybe I should bail on sunday then :gee:
Idk eh.
Any one have a 7/8s hiem around? I need a measure from the center of the hiem to the start of the thread
You haven't yet?!?
just pulled out a sliver or pats paint out of the my thumb today
You haven't yet?!?
Thanks.I got about an 1.5" thats from where the jam nut bottoms out to center of bolt hole
Thanks.
Ive been out to my jeep 4 times today meaning to measure the distance between my frame rails. Need to do that.
I under stand I ask alot of questions on stuff I dont really need/dont have the money to do.
I also dont wheel alot. I admit it. :scared: I only have on reason and thats I don't know how. The whole just floor it bit broke shit, my lack of crawling skills didnt help.
Im hoping nac fest will get me some more skills, also same for a couple of trips before it. :doh:
