- Aberdeen, MD
I have a belly button
Rotor weight might matter at speed but I bet its moment of inertia is almost insignificant compared to a huge rim/tire.And rotor weight and size.. Lotsa variables
Yep, because of diameter, torque = force x distance, and the greater the dia, the greater the distance from the axis of rotation you can apply a force. The mass of the rotor is negligable compared the the ~100 lbs of mass the tire/rim has, and the torque applied by the larger diameter rolling tire on the brake system.Easier to stop a 14" rotor instead of an 11", even if it's just holding.
Ya, I had a squishy pedal in my green Jeep, and it seemed like no matter how much I bled them, no improvement was made, and the brakes were adequate at most on road.Going to a larger bore MC gives you a stiffer pedal feel and less mechanical advantage overall.
With the stock XJ MC and larger calipers, you'll have greater holding power at the expensive of a squishier (or longer-traveling) brake pedal.
Doesn't leverage come into the equation when changing to a larger rotor? It'd be like using a 2 foot breaker bar instead of a 1 foot breaker bar, right?
Hydroboost is dumb
Hydroboost allowed me to fit a big block in my MJ.
Locks up 40s NO problem with normal pedal effort.
Doesn't slow down my steering at all.
Please explain.
Just got the paperwork started for a Walther PPK/S. Should be ready to go by the time I'm outta work.
I know Keith disapproves.![]()
Bc that's where the info is? Your jeep didn't hold bc you had insufficient clamping force. There's more than one way to solve the issue but throwing a larger bore mc on it is not the solution. I don't like Hydroboost bc I don't like two systems that are required for emergency maneuvers to be able to fail as one piece; especially when it isn't required for the brakes to perform adequately.
I use enough big words? I really don't like arguing on forums on my phone.
Just out of curiosity, not knowing what cam you've got...would your engine pull enough vacuum to make a vacuum booster a viable option?
See boldedEasier to stop a 14" rotor instead of an 11", even if it's just holding.
More surface area of pad will only affect pad longevity. Pressure and rotor/pad diameter are how you get more braking power.
He shouldn't completely disapprove. At least it's something that goes bang. Let us know how you like it.Just got the paperwork started for a Walther PPK/S. Should be ready to go by the time I'm outta work.
If the booster fails, it all just goes straight to your steering. You don't lose both. You'd literally have to crack the casting in order to lose both.
Lines don't explode on their own. They either chafe through, melt, or whatever. Route them like an intelligent person and you'll be fine. I'm more worried about my ram lines than my booster lines.
You also watched me facing straight downhill, engine off, holding my jeep from rolling down the hill no problem. And I wasn't even standing on the brakes. Nitrogen cylinder FTW. Try that with vacuum-assist brakes.
FWIW Lance from PSC said he uses hydroboost on all their buggies (at least when I talked to him a year ago) and said he would never go back to vacuum assist.
