MoparManiac
- Amherst, NH
241ORs are good for a first reduction.
That's awesome.
Try it tonight yourself and if you fail bring it to the shop tomorrow?windshield talk
I have a PPS 9mm and really like it. Everyone who has fired it has also liked it. I'd recommend checking them out. I've had absolutely no failures with mine so far, probably 400 rounds through it since I bought it (and the previous owner said he put 400-500 through it as well)What are your guys' thoughts on Walther handguns? I need to buy something soon before my permit expires and I've heard from a few people recently that I should check 'em out.
Ken I have piano wire and the handles to cut it out right come get it if you want to use it.
well, I could booger up the mounting surface and make it more difficult for them to do right. That's about it.Try it tonight yourself and if you fail bring it to the shop tomorrow?
I mean, you already have the parts/material so give it a try and save money if you can. What do you lose if you fail?
Already got the new windshield out and the old one is coming out with a utility knife so I don't destroy what paint I have left, but thanks.Ken I have piano wire and the handles to cut it out right come get it if you want to use it.
done it myself a couple times, I'm good at this :confused1 the corners really do suck, especially the lower ones. It's easier to get the new one out at the junkyard where you don't care about sawing the wire across the paint and wrecking it. I can't imagine getting one out of a jeep I cared about intact, I'd chew the shit out of the paint.Ruined one that way too, going around a corner it started cutting into the glass and broke a chunk of the corner off.
Also not a fun one-man procedure.
No issues. Beeped once every 3 seconds or so till I had the new one connected.I'd bet on it being fine. Make the swap as quick as you can, obviously, and make sure your backups are up to date... :laugh2:
I really love UPSes with external battery connectors - that way you can get a spare pack, plug it into the external connector, then unplug the internal pack, put the new one in, and unplug the external.
That depends, what is your budget?What are your guys' thoughts on Walther handguns? I need to buy something soon before my permit expires and I've heard from a few people recently that I should check 'em out.
Where have I seen those before? I know I've seen something very similar.That's awesome.
You pop in about once every 2 months. NACFest?Hey guys I'm alive.
That is all
goddamn, glad it didn't tip over on you and flatten you out.
