THe NAC Lots-O-BFG KO2 Thread
I don't know whats going on there...but I <3 the tires.
I don't think that goofy spring arm frame thinger has enough triangulation!!!1!
I just got a line on an 87 Ford front 60, kingpin, kinda rusty but not too bad, for $150 pulled and loaded into my truck. Should I pull the trigger? It's not the really nice one with the wide driver tube obviously.
If I grab this one my balljoint one will be for sale.
I had to force myself to pass on a HP60/10.25 set outta a late 80's f350 yesterday. Asking 300, probably coulda gotten them for a little less.
Id pull the trigger. Id also probably buy the BJ axle off you too.
what for? You already have one in the black jeep... I refuse to sell it to you until you have it ready to wheel if you want this one for the red jeep :yap:
I want it for a non-jeep vehicle I plan to own.
Sell me your three good creepies!!!! Offroad trike build!!!
YES
buy all 4, you need a spare anyways
wont even need to build a suspension for it. dont need flex with 3 tires
make it short enough that you can drive it upside down and put dual transmissions in it. Rolled it? Put one transmission in reverse and drive with the other.
hollands junkyard wanted 250 bucks for a turbo with significant side play in the bearings that I found on the ground.
I haggled the guy down to 79 and bought it. Think it should create enough boost to build a decent jet engine...
01 Jetta I think? I didn't even really check.
I might have to call it the TurboJetta.
87-90 gmc/chevy pickup with a 5.0 or 5.7 would be the simplest.
im looking for a parts truck.
i need the manifold, throttle body, sensors, computer, wiring, and for some reason the distributor.
i would like the throttle cable and pedal too as mine is kinda shot and a little sticky
93-94 is the simplest
Ken if you go to harrells for 'supplies' ask for Roland, if he gives you any issues tell him fat head Scotty sent you
will do, I'm a bit short on cash to be buying stacks of supplies right now though :(
