ktm racer 419
- ROW DIALIN
his penis is obviously bigger than yours
Kid from my hometown just posted this pic on facebook. Opinions?
What he said.his penis is obviously bigger than yours
I believe Cummins (FlexdXJ, this is your cue...) and International both still build heavy equipment / motors here too :thumbup:Finally a step in the right direction: Caterpillar to shift production to US
I realized after posting that I hadn't even flexed the suspension before coming in from the garage. The driver coil just makes contact with the frame bracket so it will have to come off either way. So I'll add that when I put it back together. Thanks man.Add another layer of 1/4" on the bottom of the framerail where the TB mount goes. That should lower the mount just a little bit and get the angles to match.
The fact that the rear is XJ width just made me tear up a little.Dumb question but do you guys think I could get $1500 for my axles? Or maybe a bit more or less?
Rear: XJ width 9", disk brakes, chromo shafts, 4.88s, Detroit locker, ruffstuff pinion guard, extra 3rd member, new axle bearings/seals.
Front: D30, 4.88s, truetrack, ruffstuff cover, 1-ton otk steering, otk steering trackbar bracket, and 2 sets of spare shafts
