THe NAC Lots-O-BFG KO2 Thread
Stand on a tire...? :dunno:
Tire round, bumper flat. Bumper hold drinks and food and if you drive away it's usually still there after a few feet. It also helps not smooshing my grill/rad area too. I like it, if I were to build another, I'd probably just build a simple one off the front cross member. But my rear bumper is my main concern right now. Shit just don't fit after I dropped onto the corner at FC.
Why doesn't a bumper manufacturer come out with one that replaces/reinforces the stock crossmember and mounts the winch behind it?
I'll never understand the desire for park bench bumpers.
Bolt on dude.
People that are buying those types of bumpers are not about to pick up a grinder and cut anything. It is about ease of use and installation, not so much function.
you can read ntfs on linux, pull the files over and process them. i assume youre working on an ext3 partition?
RedHat doesn't come with the drivers installed. If I had a valid subscription I could just do an apt get and it would be easy. I don't have that, so I need to build the dependancy files myself. It sees the drive and says 'This is NTFS, I can't read it.' Once I've hunted down all the rpm's it should be plug n play.
It's an external HD that I plugged in via USB, not an ext3 partition.
Can't tell from your drawing, but I'd add gussets underneath the plate that grabs the AX-15.
Are you hardmounting the trans?
Bad idea.
oopsie i forgot the trans mount, there will be a 1.5" poly mount between the trans and plate, and of course it will have gussets, havent you seen the rest of my shit
just washed my shit box. cam back to work and cant even tell.... o well at least i know some of the salt is off.
Tonight needs to be over. I neeeeeeeeeed to work on the Jeep moar. Even though I effed up the rear render trim last night it felt good to get back out there and weld crap.
i meant your linux file system was ext3.
and redhat doesnt have those drivers?! wtf were they thinking when they built it?
I should note here that RPM sucks, this is why I call it redhate and refuse to use it if there are any alternatives available. Most other linux and BSD distributions figured out how to handle dependencies nicely a decade ago.
bitches dont know 'bout my gussets
Yeah, the linux is all ext3. They have them, but I don't have a paid subscription to get them conveniently. I got the 30 day trial and that expired... oh, about 6 months ago. The files are online and the capability is there, but without a paid subscription you can't get easily.
The govt only uses redhat for linux because they want to pay for it so that somebody is accountable. I have Ubuntu at home and have the same capability and it was easy to set up, but that's open source and wouldn't fly here at work.
yeah, the government would rather spend money to have someone else to blame than save that money and use it to pay a consultant or hire an employee to figure out what's wrong with it.
Logic like that blows my mind, but big companies are all over it too.
dont get me started on how corporations' logic suck..
if an employee falls in a corporate data center and no one is there to see it, does a workman's comp form still get filed?
Ugh...class in 45 minutes.
Yup, bender is done, I won't have moneys for tubing for a while though.
