if you get one thats a pain in the ass, it's only a pain in the ass the first time. just anti sieze it all.
its good to take it all apart and lube it all up if you wheel too. makes trail repairs go much smoother.
true. speaking of which I think I need to replace one of the knuckles on the MJ anyways, hopefully the one I still need to do the balljoints on. It appears that your recreational XJ aviation resulted in it being so warped that the unit bearing basically fell out when I took the bolts off :roflmao:
reason to buy/build shackle relocation brackets :thumbup:
X2
damn straight. :greensmok
X2, though I'll probably keep AW4s in the big jeeps, I like 2 pedal simplicity (though the only vehicle I've wheeled in the last year has a 5 speed...)
pic is only after 1 coat of paint, but those who hae seen the garage know how much of an improvement it is, its already alot brighter in there
I believe it, just spray bombing the walls white probably would have helped but this will be easier to clean.
Ken left my house a few minutes ago. He has a pretty bad head gasket leak on cyl #6. Every compression cycle results in an abrubt release of pressure. Also, we started making the ramps for his m54a2... We got all the angle iron cut to length (my chop saw is da beezkneez) and one of them has been measured square and has all 24 pieces of angle iron tacked to it... I did a lot of welding. Still have to get the other one square and tack on all the pieces. Not sure if I'll burn them home with the stick or the mig. Mig is so much cleaner, but stick has a better duty cycle...
I'm currently waiting on my order from heleta to arrive before I can make much more progress on the doubler... Thankfully it'll be here tomorrow.
pretty bad doesn't begin to state the problem
about 2" of the head gasket decided to blow out of the back of the engine. I've been hearing a rhythmic hissing from the front/top of the trans or back of the engine for about a week, but wasn't sure if it was just me not remembering it always being there or not. It got way worse over the last few days, I finally got curious enough to dig into it last night and stuck my hand behind the engine while it was running. I got a fistful of head gasket, air, and diesel. I guess I got lucky though, it still runs great (though it's a dog on the highway), no coolant in the oil, no oil in the coolant, great oil pressure, etc. So it seems the piece that blew out is "just" the part that is supposed to keep the cylinder from venting to the atmosphere... guess I'm doing a head gasket (and valve cover gaskets, and intake/exhaust gaskets, and thermostat, and cooling system flush, and oil change, and... :doh
ASAP. It won't be at the car show tomorrow though I may still say screw it and drive it to lobsterfest this weekend. Anyone know of a decent place where I can get the heads decked in Worcester?
