themangeraaad
- Halifax, MA
Deep
Deep
blah blah blah
BLAH BLAH BLAH BLAH BLAH BLAH
you could of just posted the link to the songBLAH BLAH BLAH BLAH BLAH BLAH BLAH BLAH BLAH BLAH BLAH BLAH
:smsoap: yeah srsly :spin1: as a grammar nazi that always bugs me. I think the worst I have seen yet was "ur'e" however (instead of "your", in fact...)is it just me or does nac not know the proper use of thier, their, and there today?
If they're the same as exploder lines, which it sounds like they are, the second passenger line will fit fine on the driver side.Bam, and with that the disk brakes are almost done.
Regarding the calipers... damnit ford! The drivers side caliper has the splitter or T thing connected to the soft line (whatever it's called, the thing that splits the rear brake fluid to the two sides). I either have to plug up one of the outlets on the splitter or buy another passenger side soft line (which doesn't have the splitter) and hope it matches up to the drivers side caliper OK. Not really a big deal, just an annoyance and another $17 out of my pocket.
Anyway, off to add another coat of paint to the backing plate and to look for my flaring tool. Hopefully the tool is in my garage bag, otherwise flaring waits till tomorrow when I have light to dig around in the shed.
Good to know. I thought they should but I wasn't sure. I'm actually almost certain the calipers are identical from one side to the other. The backing plates are the same (one caliper sits behind the axle and one sits in front) so it makes sense the calipers would be as well. Just checked NAPA and it says that the passenger side is 'available now' so hopefully I can pick one up on Friday afternoon.If they're the same as exploder lines, which it sounds like they are, the second passenger line will fit fine on the driver side.
Way ahead of you. 2nd Soco and coke just poured.but its only wednesday. Perfect night for drinking!!! :thumbup:
wayyyy ahead of you and thinking about my first soco and diet pepsi with lime![]()
I prefer coke for mixing myself, but lime is a good addition, I'm just out of lime juice at the moment.wayyyy ahead of you and thinking about my first soco and diet pepsi with lime![]()
I like my scotch but for a week night I will mix a soco and coke or gin and tonic. A good glass of scotch once in a while and a cheaper whiskey (burbon or otherwise) for "normal" drinking.my ex really liked soco and lime... I am more of a fan of whiskey mixed with MOAR WHISKEY myself.
If this house purchase goes through (lawyers are wrangling atm)... you guys are more than welcome to show up for the first/last bender of a party that will occur shortly after I get title. Bring your gas cans of booze.
Well, there will likely be more parties, but none as wild as this one. This one doesn't really require the walls to remain intact so long as the windows/frames are not broken, future parties will require that people don't damage the place... thus the first/last bender.And first/last? Only one? weak. Or is it the only party that will occur shortly after you get the title, i.e. there will be more to follow just not 'shortly' after you get the title![]()
that was a piece of cake, i did it with blown motor mounts
You and that damn drink. You have my birthday to thank for that.
I'm a fan of apple juice.
Ford power FTL
