THe NAC Lots-O-BFG KO2 Thread
It's just some poor dude with a faulty trailer tire, he tried to get it replaced thru Maxxis, and they bounced him around to a million different people, basically tried blowing him off, and it took ALOT more than it should have for them to do the right thing. Took em over 7 months!!
Did that answer everything?
Yep, I'm pretty sure it did!
so ur telling me that thing i ripped out and threw away was valuable?
Likely, unless it was just a dash clock. To really be valuable you would have to track down and pull all the sensors that came with it - at least one on each diff, I think ANOTHER CTS, probably transmission fluid temp sensors, etc etc etc. Otherwise it'd mostly be a curiosity.
it had a clock but it had a bunch of other lights in it that never turned on so i dunno what they did. but the stock axles and trans left a loooong time ago
you got a picture of one of these, what exactly do they tell you.
Wish I could find one. I saw one on here long ago, and Google is failing me because Chrysler had to go naming the new security key setup the Sentry Key :smsoap:
EDIT: looks like they check fluid levels (at least the front diff and maybe the rear) but don't do much more.
shalamalacka...
Vote in RotM if you haven't already... one vote between #1 and #2 right now.
I know we've got no NAC contenders, but vote!
Note To Self, save money from next 3 paychecks, that with part out blue jeep money= Atlas
Can I borrow it while the rest of your Jeep gets built? ;)
What are you looking at, 2 speed or 4? What gears? What outputs etc??
2 speed 4.3 low range 32 spline frt output, not sure on yokes or flanges, whatevers stronger i guess
I want the 4 speed, I just priced out what I want with the options etc, comes to $3,041 :eek: with the 32 spline front output, 1350 yokes, speedometer, VSS tailhousing, and the XJ shifter. yikes. Gonna be awhile til I'm not worrying about blowing up my t-case :( At least I have a spare in the meantime haha
where did you price ou yours i was close to 2500 with mine through polyperformance, still aint sure where ill order it though
I just did it on the Advance Adapters site quick to get an idea
on poly performance's site, after shipping, the 4 speed with the same options listed above came to $3,049.35. I don't know if shipping is included in the price on the Advance Adapters site...
came to 2300 with 1410 yokes on advanced, there you get the hd ouput for free when ya order online
sweet. Yeah, I dunno. The price of the 2 speed is obviously more attractive, but if I'm gonna spend that much money, why not add $800 and get 2 more speeds? Might as well, IMO :dunno:
you like to many speeds, that be like 10 speeds total wich would confuse the shit out of me, maybee you on speed thinin of all theses speeds
You'll be done by fall/winter I bet...
Go ahead, prove me wrong and finish sooner :D
i would probably mean missing nacfest then
weld both diff and bring it to lobsterville, then have ross trailer it back home
i plan on having a broken black jeep on there:D
have a link handy? I'm curious :)
STOP LOOKING AT MY TIRES!!!
Get a second pinion nut. For the $2 it isn’t worth wrecking the threads on the new pinion using a old rusted one. Use a brand new one for all the setup, then use the 2nd for the last final assembly so it’ll have been only tightened once.
:gee: that was funny
