http://naxja.org/forum/showpost.php?p=244774363&postcount=8
Ken, you don't need the side bearing puller unless you arn't making setup bearings out of old ones (or in Colin's case, new ones), save the $300.
You'll need:
- Patience
- A good micrometer (if you have to buy one, get Starrett or Mitutoyo)
- A drop dial indicator, mag base, dovetails and swivels (again, if you have to buy one, get Starrett or Mitutoyo)
- 3lb and/or 5lb deadblow
- 0-30ish in-lb torque wrench (beam style or fancy max load)
- 0-250ish ft-lb torque wrench
- Die grinder or similar to make setup bearings
- Long pry bar
- Patience
