foxwar71
- Foxboro, MA
i regret not buying it when i first saw it
hey sam, those rockers look good. but i think i'm going to take a different approach to mine a little bit.
Nice, got underside pics too? why does nobody wanna cut their doors and go higher though?:dunno: i want the bottom of the rect tubing to be where the bottom of the door is now.
such as
BUT rockers being low and hanging out a decent amount isnt a bad thing and has kept me from going over once.
i also don't like the "steps" on the underneath you get when you trim the door a couple inches and weld them in making your floor very vunerable. i would have to pretty much make some wannabe mini boatsides by then to be happy and that is like 6 times the amount of work.
adjust the steering stops on your knucklesMy tires rub my LCA's![]()
not sure yet. farther front to back i think. probably will cut the fender back some more at the bottom so that the fender doesn't get welded to the 2x6 because that would be silly.
Wow, actually very similar to what I was going to do... and by very similar I mean the same thing except I wasn't going to attach it in quite so many locations (though I might as well do it right the first time I guess :laugh
