- Columbus, In
So I may not be the only gooseneck'er at the campsite?
bm 'if only I could fit a camper and the XJ on the trailer' yohn
Put you a RTT on top of the goose! :cheers:
Got the front of the XJ lifted tonight, if the rear goes well and I can fix this intermittent starting issue then I may bring it to WF. The ZJ has been solid and reliable though so it's tempting to say screw it and bring that instead.
Your supposed to leave the easy end "the front" for last.
Well, this list started right after WF Oh-Ten ended, some things have been taken off the list since I got them done. Most of the original list is still there with a bit more added. OBA, Aussie for the 8.25, V8 ZJ steering, Gas Tank Skid, T-case Skid, Reinforce Bumper, Tool Storage, Motor mounts, Rocker/Sliders, Cruise Control Servo, 3" lift, Coil Retainers, Trans Cooler, Brake Line Extensions, 31s mounted and balanced, Disco Sway bar on, Trans Cooler, Battery Terminals, Neutral Safety Switch, Out with the A/C, Relocate Alternator, get a few more camping items...Maybe hood vents
How much lift are you doing?
