Money_Pit_Incoming
- PA
I plan on switching to a higher viscosity next oil change, I just had the 10w30 on hand from when I bought everything to replace the head. Was hoping the oil pressure would come up again being it suddenly dropped when the coolant leak got worse, maybe had a max of 200 miles on it at that point since the pressure dropped (2k miles on the oil/filter at that point)... I changed the oil, put dye in and drove another 30 miles when I verified the crack. I was really hoping it was just thinned out oil, but apparently not lol.
I'm planning on pulling the oil pan still, just because there was a lot of sludge still in the block. Seafoam treatment didn't seam to pull anywhere near what I expected out, although I didn't expect much to begin with. Rear main seal does appear to be seeping, even though it was replaced maybe a few hundred miles before I got it and I've got maybe 2500 miles on it since then. I don't trust any of the work that was done to it by the guy my uncle had do it for him... most of the oil leak that ever other gasket was replaced to fix, seems to have been the head gasket seeping oil and the oil pressure sender. The gaskets that guy replaced, including the valve cover were still leaking when I got to it. Engine is basically bone dry now after I got done and 200 miles later.
I wouldn't be surprised to find sludge in the pan and pickup, as well as a damaged bearing/cap at the rear of the crank.
I'll post back after I get to that point
