I had some extra time to play with the Cherokee this weekend and I needed to do a few things to get read for trail rides in July and August. The first thing I did was get the mini skids installed.
Worth noting is the size difference between my Currie mini skids and my kid's old JCR skids. Not sure if you can see the thickness difference in the photo, but my smaller Currie Enterprise skids are the two on the left. The JCR skids are on the right. Thicker may look better, but it may increase the difficulty in welding them to the thin control arm brackets.
I wheeled for a year with this rig without mini skids and my LCA brackets were beat to hell and mushroomed. I straightened them as best I could with a BFH, a grinder, and a large adjustable wrench. I used a large C-clamp to hold the skids into position and tacked them in place with my crappy welder.
I have not welded since high school 29 years ago. I used to make cool jack stands, and I think I even turned out a few grappling hooks and rock hammers in 12th grade metal shop. I used the grappling hooks to hang from cliffs near the American River and watch the rafters float down in their rafts. Ahhh, good times.
After figuring out how to make the wire feed properly and setting the power setting on the crappy welder I bought, it seemed to work out just fine. I'll pay somebody to weld the critical stuff for now....
I found a like-new 90W mig welder in a garage sale for a good price. It came with an auto darkening face shield, which did not exist when I was in high school. Welding is fun, fun, fun, fun, but make sure you also buy some leather sleeves, cuz hot meal sucks when it lands on you. I made to sure to remove the lower control arm before welding up the skids and I ran a bead inside and outside each joint. After the sides were welded, I beat the front of the skid down to make contact with the axle tube. I removed the old paint with a wire wheel first.
I won't be showing anyone my welds up close, but they did not turn out too bad considering the last time I welded Boy George was playing on the radio. Aggressive application of my 4" grinder and a heavy coat of paint inside and out finished the job. Control arms slipped right back in with no problems. Make sure you take the time to torque everything down while you're under your Jeep. Karma-Karma-Karma chameleon. WTF?
I'm anxious to try them out on the Rubicon and Deer Valley in the coming weeks.
[end]
