Tera 2 Low kit with a wide chain
Here is what I came up with......
Rocker arm studs ARP 200-2403 nuts for use with HS roller rockers ARP 300 - 8331
Valve cover studs ARP 200-7603
Head bolts ARP 146-3601 studs are ARP 146-4201
Crankshaft main studs ARP 146-5401 bolts are ARP 146-5001
Oil pan studs (1/4") ARP 200-7601 (5/16") ARP
Flex plate bolts ARP 146-2901 Flywheel bolts ARP 146-2801
Some misc studs had to be extended for auxillary items to be mounted.
All exterior/gasketed nuts were SS serated flange nuts.
All the misc hardware I got from McMaster: Transmission studs - SS 6mm x 1.0mm x 25mm
Transfer case - SS 10mm x 1.5mm x 50mm
TC tail cone - 8mm x 1.25mm x 35mm
I was literally ready to pm you for this info lol. Thanks!!
Did they quit making the TeraLow 4:1?
Not seeing it on the TeraFlex website.
Or a TJ Rubicon is a better fit. I don't know when TeraFlex dis-continued the 4:1 as I installed mine 19yrs ago. I did buy a NIB Rubi shortly thereafter for my Cheromanche project.
Teraflex:
TJ OR241:
