- Lakeside, CA
Can't tell, but did you do the 6 gear planetary, or stick with the stock 3 gear one? I should rip my case apart and add the 2 low. Already have the wide chain and 6 gear in it.
Did you get the boostwerks linkage to work with 2low? I gave up and went back to my Novak cable shifter
If it's available it's from ARP, the rest are grade 10.9 stainless.
No such thing as 10.9 stainless. It's either 10.9 If steel or A2 or A4 if stainless.
I want to add that my "trail" gas mileage went up as I usually will run all day in 4lo and now I just do it 2lo. With the "shift on the fly" feature it becomes seamless when you need extra traction.
Mine has been absolutely prefect in all aspects. No installation issues and the 2-low is a great feature.
I have enjoyed this collateral benefit as well. The only negative that I have experienced with the 2Lo feature, is sometimes when crawling along on the trail and I come to an obstacle which needs the front end engaged to climb over, I forget that the t-case is in 2Lo and not in 4Lo.
