souske
- The land of competition
In!
Bad idea, bad idea!
So...
why do we run CV driveshafts on the XJ's?
Is there any reason we can't go to standard yokes on 4643 and run standard driveshafts?
Bad idea, bad idea!
I have decided not to have kids.
The kids are taking it pretty hard.
as long as you can get them to be vibration free and work properly throughout the whole range of travel.
YJs had standard yokes at both ends of the front driveshaft from the factory. not a lot of travel though.
are the double Cardans a problem?
Coming to the XJ world via years of buggies and other stuff I have always been a little confused by the double cardan rear shafts. They have their place, but it's usually on things with really short rear driveshafts. XJ's don't have a particularly short rear shaft, and most other vehicles of similar dimensions don't run CV's. I've built dozens of vehicles, and had probably a hundred driveshafts made. I have a very solid understanding of the dynamics and design. Very few of those had CV's.
It kinda strikes me as one of those things that someone did way back when, and it worked, so all his friends did the same, and now years later it's just what you do, just because it's what you do. My only theory is that it's because someone discovered that you can swap the rear yoke and use a stock front shaft in back, and then it just ran from there. I'm trying to figure out if there is any reason to do that if you're building everything from scratch though.
people started swapping DCs in when the SYE became a thing to give the driveshaft increased working angle, which is especially helpful with Wronglers.
it also makes it much easier to build a rig since the only angle you have to worry about is pinion angle at the axle, which is much easier adjusted, by the inexperienced first time builder, than at the transfer case.
I think this is more a byproduct of the fact that all the SYE's were primarily developed for wranglers where the short driveline length necessitated a CV. XJ guys bought the SYE because they both have the same transfer case, and since the SYE comes with a CV yoke, they just put on a CV shaft.
Lots and lots of vehicles out there with similar length shafts run single joints without vibrations. As long as you're within the working range of the joints setting it up to not vibrate is not difficult. You just match the angle of the t-case output with the angle of your pinion.
