marcusguy
- Jing Zhou, China
Well, I got my rear end in this evening. After I set the gears up and got a good pattern, I pressed the final bearings on and put it all together. I checked the pattern a few more times just to be safe and it seemed the more I played with it, the more my backlash tightened up. I decided it was the marking compound just gunking up and making everything tighter. I took it for the first drive tonight and I had no noise when on the throttle, but pretty bad gear noise when coasting... cut the test drive really short. I thought I heard once that backlash to tight would cause a symptom like that... is that true?? Just want to know where to start when I open it all up tomorrow.
Marcus
Marcus
