Frank Z
- Colorado Springs
Since I built the bumper I feel more than qualified to address this post.My bet on why it broke the grille - the bumper was likely flexed a bit forward from the tension on the line, when the line suddenly went slack because of the winch nuking itself, the bumper snapped back and threw the winch remains into the grille. That plastic gets pretty brittle in the cold so it wouldn't take much to break it, chunks of winch thrown from close range would do it easily.
The bumper can't "flex." 1/4" plate and gussets under the winch plate make it rock solid. I've been using the same basic design on my rig and sold quite a few others as well. If it were a design flaw there would be an angry (and ugly
As for why the grill got busted, the winch is mounted very close to the grill. When the rear mounting point broke the winch rotated rearward and the rear twisted up and back into he header panel.
Keep in mind that the drum is being turned in a clockwise direction (when viewed from the passenger side). When the mounting points fail, the motor is going to continue to turn the drum and any other parts that are no longer secured. Considering that the winch was in use and under load, the damage to the header panel is not suprising.
Make sense?
