Did he have to do anything to get it on? I'm assuming he's running the 99+ fuel rails and TB
Caution on resurfacing the flywheel. The factory says you cant. The only reason is that the clutch pedal has no adjustment and will be closer to the floor due to the increased throw necessary for the amount of metal that is removed.
Personally, I went with a Howes racing master cylinder. I got a slightly bigger diameter than the stock and made a quick adjustable adapter from the rod on the old MC.
http://www.naxja.org/forum/showthread.php?t=913747&highlight=flywheel
. I like a fairly high clutch pedal and a firm engagement.
I also created a new throttle stop to prevent the throttle blade from travelling beyond WOT, and created a stop to hold one end of the throttle shaft spring so that the appropriate tension
Yes that's mine.
What did you need to create it![]()
created a stop to hold one end of the throttle shaft spring so that the appropriate tension was maintained
I have read through all this and some others as well and still have question's regarding my particular combo of head,intake,etc.I have an 87' ,keeping Renix system,93' head,and 99' intake that came w/TB,fuel rail and injectors.Can the 99' fuel rail and injectors be adapted to the Renix system?,should I get the 93' rail & injectors and use that?Also,will closing off the EGR tube affect the Renix system?Any input would be greatly appreciated,my head gasket is taking a dump and this may have to happen soon.
I dont' have to worry about inspection's,I was more concerned about what effect's there might be to the Renix computer.I read about adapting the newer fuel return to the Renix,but the 99+ has no fuel return.Will injectors from any year,87' to 01',fit in the 99+ intake?EGR can be blocked but this will make your vehicle non smog legal depending on state.
the fuel rail for the 99+ will work on the renix but you have to modify them this was mentioned somewhere in this thread as well
