stupid speedo question
h.curtis
Pittsburgh, PA
Did a search and came up with either a 34 or 36 tooth. Don't know if having a 5sp makes a difference. I have 33 KO's and 4.10's. I had 3.07's with 29's stock I think.
Sorry if this is too stupid.
Curt
Curt
According to my calculations it should be 34 tooth... but for the calculations I assumed that what I got from the factory should be right, which I don't think it was. Anyways, those same calculations pointed me to a 36 tooth speedo, which gives me about 4% error (80 on the clock and I'm doing only 76.5). Btw, how do you like your 33's with the 4.11's? I'm thinking that when I will go up to 33's I will want 4.56's very soon there after.
Thanks. I did a lot of reading on what gear to use. I would have gone with 4.56's if I had an auto. I like my 4.10's on my set up. The reason I went with 4.10's were because I am running 10.50's and have stock bumpers and no winch or anthing. I am pretty light so I figured 4.10's would be ideal. I also have a full Borla exhaust and my low end torque is strong. That is the reason I choose 4.10's. I think 4.56's would be a good gear if you have some extra weight or an auto. Most people want the 4.56 and I can understand why, but for my set up I am right on.
Curt
What in the heck are you doing with teeth in your speedo?
Do you know whose teeth they are?
Is there a story?
I wear the Speedo Jr., in fishnet, and there is no way I could do the European Crawl without incurring serious damage with any type of sharp bits of calcium in my swimwear.
Perhaps you should consider a drysuit?
Or keep the teeth in your swimcap?
Best of luck in your endeavors.
Hasta.
Is there a story?
Hasta.
Figure out what your speedo error is and change the gear by the same percentage. If your speedo is 5% high, get a gear with 5% more teeth. If the speed is 5% low, get a gear with 5% fewer teeth. You can use a GPS to compare your speedo against.
Well, I don't have GPS. It is reading way high. I think I'll slap in a 34 and see how it is. Although I would rather read low than high.
Curt
Curt
If you got AAA, find out from them when are they going to be doing speedo checks in your area.
