RangerRick
- Longmont, Colo.
My speedometer has been bouncing around for some time. Then last week it became clear it no longer was reading right. Finding no teeth on the speedometer gear, the problem was clear.
? When replacing the gear does the speedometer gear housing (that part between the gear and the speed sensor) need to be clocked when I've changed my gear ratio from a 4:10 to a 4:88? Or does the drive gear on the transfer case main shaft have to be changed to mate up with a 41 tooth gear?
