1986PIONEER
When my '86 Cherokee arrived from Arizona this fall the speedometer was working just fine. Now, speedo/odometer are only sometimes jumping a bit and then dead as a doornail. As with all early XJ's, I have the cable run speedometer. the Jeep also has cruise control so there are really two cables with a speed sensor in-between. I've had the cluster out and speedo removed, turning by hand it revs up just fine. for a cable test, I pulled the speedometer cable end and gear out of the transfer case and hooked my drill up to the cable....the speedometer worked absolutely fine. So it must be the gear, right? 19 tooth gear, factory original, looks a little worn. Teeth have a concave wear pattern. I get a new gear from quadratech, it's identical but with nice square teeth....put it in, speedometer works fine for about one block in my neighbrohood, then bounces a bit, and dead. cables are all connected and clicked in as should be. I'm all out of ideas.
The only thing I can think of is perhaps the corresponding gear inside the transfer case is bad?
