- Roanoke VA
Long read, bear with me!
This jeep has been trouble free for 20 years. I recently broke a rotor button and when replacing I found play in the distributor shaft, I replaced the distributor. I immediately got a code for the CPS. I replaced the CPS since it was the original with a NTK. Code came back. I read where some new distributors have the drive gear indexed a half tooth off. I pulled my new distributor and that was the issue, I swapped the shaft/gear from my old distributor to the new distributor, problem solved.
It drove perfectly for a week.
Then I get a code for the VSS, my speedometer quite working and the trans would not shift out of 1st gear. I replaced the VSS and pigtail (they don't make the 96 obd2 VSS, I had to use the 98-01 VSS which requires a different connector)
Fixed that issue.
Now I get a code P0123 out of the blue. I have a new NTK TPS on the way but I'm still not convinced that's the issue.
What are your thoughts?
Fixed that issue.
