Pyrobuilder
- Mint Hill, NC
I wouldn't think so but it might
You can verify by disconnecting the lines at the rail and turning on the pump. The supply line from the pump connects directly to the rail, the return line connects to the regulator
I put the new injectors in and still nothing. Got a throttle body from the junkyard, im under the impression that the IAC is the problem. Took it out of the old TB and it was stuck in position. Cant remember if it was open or closed all the way. any other suggestions that might help ?? :flamemad:
