Speedometer pinion (gear)
boise49ers
Boise,Idaho
1988 231 Transfer case. Non-electronic. Vacuum I think.
I have just installed a new speedo gear aka Pinion. The marks for lining up the correct set of gear teeth are on the cable side that the gear slips into, but I can't find one around the hole on the transfer case. There are marks for the fork that holds it in the transfer case. Do I use those marks to line up the tooth set ? If so, do I use the upper or lower mark ? No little dots like the newer Transfer cases.
I did do a search and they didn't answer my question. :)
Thanks
Actually after going and looking at it again the marks for the fork are on the same side as the cable so those won't work. Guess I just move it around until I find the secret spot.
