smokinu
- Modesto CA
Hit me up if you head up 108. I haven't found anything more than rough forest roads so far and would like to explore with people.
i wouldnt mind this either. :roll:
you need a new potato
please let me know if the high flow fitting on the pump is bigger than stock and if the resi is bigger than stock. after doing some reading I found that there seem to be no differences between aftermarket pump internals vs. stock. but they didn't mention reservoirs which will make a nice difference if it's bigger
doesn't come with a res. and Ill let you know on the fitting. From what he said, there are 3 different internals for the TC style pumps. I want to go to pnp and grab a WJ reservoir to see if it fits.
