Something happening on the eastern front.....
You're more east than I am. Have you made it to Randolph or Kansas Rocks yet to wheel?
You're just about as close to Disney Oklahoma as you are to Randolph or KS Rocks...
Those are the closest places that are public wheelin' (unless you like mud, then if that's the case, there's the Kansas Badlands)
nope the jeep is still stock, i gotta do an axle swap and fix a mystery oil leak first befor i start upgrading it. Ill be sure to check them out soon though.
mudding, not a big fan of it. Im originally from Co and theres not alot of it out there im more into crawling
just throwing in a new 8.25. the one in the jeep now makes a grinding humming noise. although im not sure what it is exactly i know its in the gears somwere and its cheaper to just swap the axle out plus i pulled it from a 98 so its the 29 spline intead of the 27.
the only reason i never pulled this one apart is its still drivable and i have a bad feeling as soon as i open it up it no longer will be and its my only trasportation haha. eventually ill upgrade to a locked d44 when i get back home
