Some stuff I made for my XJ (built thread)
As far as the rear flare I have min on the same spot I used 3m tape and they have been on for over a year have taken some hits and never poped off.
What width are the tires 12.5 or 10.5 I have 3 in lift so it would be nice not to have add any bumpstops.
Very nice work!! :cheers:
Differential slider
Hi all
I asked you all last week about a design opinion for my slider, and I sent this picture
I decided to build it. I'm keeping notes on everything I do on it, so if anyone ever wants one I'll be able to replicate. So here is the plate folded and cut
I then layed under the XJ, and I discovered that I needed to shave a bit on the side so I don't interfere with the exaust. And it makes it prettier also
Hi all
Bringing this thread back, but since it is my built thread I see no problem. I had the opportunity yesterday to try a ramp with my XJ. I don't have RTI numbers or anything, but I'm happy with this flex that I got with only a 2 inch spacer/shackles.
Those are 33 tires, TJ flares, 2 inch lift, and proper bumpstop
I'll try to finish the diff slider soon....more pics to come about that
Hey, reading back this thread I see I did not include my crossmember/t-case skid/tranny skid, so here it is.
I managed to bend the stock crossmember on a trail ride
So I had to make another. I bought a c-channel, and I did this heavy-duty crossmember
I like the skids and design, but I gotta say man... those welds look like dookie!
Other than that, nicely done. I need to work on under armor for mine too.
~ James
Yeah I know about the welds. I never welded before I made the bumper, and it is a stick welder. IIRC correctly I had a trouble with the setting on the last piece, and I found out after I was done.
Practice makes perfect I guess...
