Gerr
- River Drive Norco Ca 92860
brake rotors $30 for both (from 93 xj used for about 3 months never turned and are cast iron not composite)
brake calipers $30 for both (from 93 xj used for about 3 months no leaks good condition)
non disco HP dana 30 $100 comes with shafts, hubs, and internals (no leaky seals, 3.07 gears)
chrysler 8.25 drum to drum $100 comes with 29 spline carrier (no 29 spline shafts)and 3.55 gears (27 spline 3.07 gears installed no leaks no bad noises)
2 xj vacume bottles (oval shape) $15 each
chrysler 8.25 27 spline axel shafts $40 for the pair
2 new 4.0 oil drain plugs $4 each (has large rubber seal as part of bolt)
4 235/75/15LT GENERAL at's with 70% tread left $120 (very good traction, load range c nothing wrong with them I just went to 31's)
