So Cal Karma 2008
Status
Not open for further replies.
its only 1 tire
Got a home brew trac bar. It was a skyjacker bar made for a TJ. A buddy of mine on the islands tweaked it. I was running it at 6 inches. Also included is a relocation bracket, a little tweaked thanks to bronco peak. You will need a new heim joint. Just got a new bar so offering this up.
Paul, I may want that. I will PM.
non-jeep related but come get it before it goes in the trash:
1. nearly full bottle of cement latex primer about 30 oz (used for priming before using self-leveling compound)
2. 35-40 lb bag of Sand Topping Mix (sand and portland cement mix)
I'll take 'em. I got a project that wil be able to use them :D
89xjJe3per said:
First the seats. They are in GREAT condtion one little flaw in the driver but the pass is flawless just needs a good cleaning.
Still got the seats...
Bump... and homebrew i havent forgot about ya just been working ALOT :viking:
Two one gallon bottles of RV Coolant, the pink kind in the opague plastic jug that looks exactly like the kick ass bug guts dissolver washer fluid :(
G.C. Front Springs for 6 cyl. (Oops)
Don't know what I was thinking when I pulled these, but someone before me dropped the axle and they were just hanging there by the mounts . . .
Came from a Grand Cherekee with 6 cyl. and not the 8 cylinder car that gives a bit of lift on Cherokees.
And they measure;
Hight 17.5 in.
Diameter 5.25 in.
Number of coils, max. count 10
Diameter of wire 14mm
$xx- works for me. (My loss is your gain)
P.M. if you like.
Phone is better; 562*698=OO89
Mike
'89 Header Panel
'96+ Washer bottle
'98 4 Door Panels including hatch panel (Door latch may be gone by the time you pick them up)
'98 Power window motor & parts except for front driver.
'89 & '98 glass for all doors & hatch.
'98 rear wiper motor.
You will need to take the windows & power window parts yourself.
Just let me know..
E
EliasJ123 said:
'89 Header Panel
'96+ Washer bottle
Just let me know..
E
I'm sure Kevin H and I could use that 89 header panel. He's on his second or third, I'm on my second.
Got Rock Garden?
Got some "good stuff" to get rid of.
Left to right: Stock front skidplate, cheap Harbor Freight creeper, badly damaged center crossmember (it just ended up in the picture :D), and stock transfer case skid.
Here is a picture of one of my old seats in case anyone is still interested:
Come and get this stuff. It will be thrown away soon otherwise.
Ill take the seats if you have both... and if we can get them trained a little closer.
Thanks E. Gonna pass on these though. Shouldn't you be changing a diaper??:laugh3:
EliasJ123 said:
'89 Header Panel
'96+ Washer bottle
Just let me know..
E
EliasJ123 said:
'89 Header Panel
'96+ Washer bottle
Just let me know..
E
Hey E,
You have power door locks from those doors?
bpk
GrimmJeeper said:
i'll take both of the skids if we can figure out the train possibility :D
DIBS!
:cheers:
They are yours. Let's see if we can't work something out. Maybe I can finally buy that tow strap that you ordered for me like 6 months ago. :D
Status
