- Hammertown, USA
GrimmJeeper said:these are back up for grabs
set them aside and i may try to put them on my trailer
cool I'll take 'emGrimmJeeper said:probably, but they are pretty long, and might be a bit soft for an XJ
too late calcal said:set them aside and i may try to put them on my trailer
Can you PM me the numbers on them?GrimmJeeper said:too late cal![]()
i would but they are too old i cant read emcrazyjim said:Can you PM me the numbers on them?![]()
Hahaha, ok... I'll pick them up from ya at the chapter meet?GrimmJeeper said:i would but they are too old i cant read em
wont be there. im the one that started the whole stink about not making it cause its not a weekend lolcrazyjim said:Hahaha, ok... I'll pick them up from ya at the chapter meet?![]()
you're gonna do WHAT with my nuts trips?RªMB° said:I can pick up the shocks for you Jim since I will be down there this Saturday. Im still trying to find a cordless drill I can borrow for your nut strips.
Clean-RC said:Ok I have a 10LB roll of .020" welding wire for the mig.. I tried to use this on my last project and my machine is toooooo picky.. Come pick it up- - will not ship at all.. Lots of wire left...
2stix said:.020 is a small wire. did you happen to change the roller? most rollers have two grooves. one for smaller, one for larger wire. you can unscrew the roller, flip it to the correct side. when you try to use the small wire with the larger groove (or even just a dirty groove) the roller will just slip making you think your trigger isnt feeding wire. or it will feed alot slower as it slips no matter how much you turn up the spring presure on the roller. also note that the .020 wire will burn quikly and often will burn up into the tip and glog it. the wire may come back through but inside the tip there is contaminants that is scraping and dragging the wire. you need to reem the tip ever so often aswell. or just change tips. just a few pointers on why you may think your machine doesnt like the .020 wire.
Clean-RC said:..I just gotta get Kyung to come over and show me how to use my TIG properly....
EliasJ123 said:I've been saying that for the last year.. :doh:
Maybe.. I'll have a small welding party, before our due date, since Kyung is only a skip away from me.
E
Surely.....Brendan_91XJ said:can I come over too?![]()
I tried the thumb trigger man it sucked2stix said:actually you are going to end up useing your TIG for sheet metal work once you learn it. the mig for tacking, tig for welding. its actually pretty easy to learn the tig, especially if youve learned oxy/ace before. same principal basically, you just adjust electrical curent instead of gas. i had a bit more to learn as i have to use the thumb trigger, which takes a bit to get used to because it tends to make you a little unsteady with the torch while adjusting. id imagine the foot pedal would be easier.
not sure how the snap on mig works, but when i use .020 with my 220V miller i use the lowest setting and speed up the wire a bit. like i said that small wire burns fast. my 110 lincoln works the same way, but some mig machines actually give more amps as you turn the wire speed higher. all depends on the machine.
Gerr said:I tried the thumb trigger man it sucked
TIG really is pretty easy to get going but to make pretty welds it takes a lot of practice.
