" Stock XJ Clutch fan pull 2,000 CFM.
Stock XJ auxiliary E-fans pull 1,350 CFM."
This is a real world test!!! Not speculation. The same person tested post a triple threat install and he measured 3400cfm total. I don't know if he has ffdynamics or dirtbound setup, however these are real numbers measured with the same tool. I have not found a cfm rating with the zj clutch though.
Been doing lots of reading and I found this on naxja. I also found that per manufacture, the xj requires 2000cfm for light use and 3000cfm for heavy use/offroad/towing. This means if my fans are actually putting out 3300cfm, I don't have an airflow problem.
