So, are you ready?
Update:
hook up my new 2M - DONE
get alignment - DONE
whooppeee. At this rate i'm gonna be ready for enxt years event
Update:
You do realize that as chapter prez you are in no way expected or obligated to show up, right?
Audit recovery bag - DONE
Audit survival box (been a long time!)
See if my 30 is bent
Align front wheels
Put more air in tires
Check for damage from JV
I'm on track!!! I even charged up the red Jeep's battery and let it run for about twenty minutes this weekend.
Oh god...
Install re 4.5 (happening the 13at andys)
Diag my front drive train issuse
Find/buy front tow hooks
Install rear factory hitch
Buy and install sliders
Swap out steering gear box :( fml...
ah sweet!
screw that. If I contribute, plan, and whatnot...I'm gonna be there.
Get new tires: Check
Install new tires: Soon as I get home
Gear and lock front axle: Check
Late model booster swap: In the mail
Gear 8.8: check
Install 8.8: waiting on parts
Install drop brackets: As soon as I get back
New steering: Design, build and install when I get back.
Im sure I'll find more, its been 7 months sense I have seen my jeep.
well...
install the new high pinion dana 44
install the rear dana 44
build my steering
build my long arms
build my steering/have it aligned
put the 35's on
Sawzall fenders
Fix coolant leak (duct tape?)
Reinforce wooden roof rack(duct tape?)
Figure out rear bumpstop extensions (duct tape?)
Figure out cupholders (duct tape?)
Buy duct tape.
build and install roof basket - done
install tire carrier - done
install extra lights on roof - done but need more
build and install rock sliders - ummm starting soon
convince wife to stay home with kids that weekend - screwed!!!
find money for the trip - checked wifes purse - got it covered
buy beer and meat - pending
i guess i still have work to do
Sawzall fenders
Buy duct tape.
this made me chortle. lol.
-install 8.25
-figure out suspension setup
-buy cb and install
-take basic test, buy 2m, install
-buy roof rack, install
-install rock sliders
-buy fridge
etc, etc....haha!
To Do List
I have to:
  • Re-gear the rear axle and get it installed
  • Plate the front drivers frame rail and wheel well
  • Locate and buy 15" used bead lock wheels (I don't have any wheels now :cry: )
  • Fab up a new trackbar bracket
  • Paint the rig white
  • Fab up and install a new high steer setup
  • Fix the transmission pan leak
  • Figure out the 'tight' issue ont he front axle spindles
  • Fab up rear bumper
  • Adjust exhaust so it won't hit the front driveline
  • Finish up the wiring of the transmission
  • Finish modifying front bumper
  • Modify and install new Durango steering box when it arrives
  • Build a full roll cage
Only 5 weeks to go.......... :D
Re: To Do List
What you got left to do to go to the Big Bear event?
I have to:
You could always just ride with Cal?
:laugh:
Re: To Do List
I need to throw some plate on the truss that broke last weekend, possible some tube work on the rocker replacements, and get some gas!
Re: To Do List
I would like to do the following (dunno if it will happen):
Paint and Install my Rear quarter guards
Repaint my rear flares along with the guards
replace trackbar superflex races
replace trackbar lower axle end bushing
realignment
replace my bent 8.25 shaft
WJ knuckle conversion if I'm lucky
Re: To Do List
realignment
That isn't too bad. It'll be a LONG weekend if you lay off the beer :laugh:
Re: To Do List
Well, I made some progress this weekend but not as much as I would like.
I got the rear axle re-geared, sealed, and installed. Has a great pattern as well and so far the seal job on the shaved rear 60 is not leaking :D
I found a set of temporary wheels so I could mount my tires and it now rolls around. Still looking for a set of 15" beadlocks though in the meantime...
I have done all the necessary bodywork and wetsanded the rig. The necessary trim has been pulled in anticipation of the paint as is the mirrors and other incidentals. I have an Easter dinner tonight so I am going to paint it tomorrow. :bunny:
A little odd luck. The casting of my steering box broke so that delayed some of my progress here today while I fiddled with that. Luckily I have that Durango box showing up soon. Very wierd. :wierd:
All this plus I shortened a HP Dana 44 front to waggy width. I am tired.
Off to the back for more work.....
