Good to see you pop in every once in a while Aaron! Maybe you can help me out with this list - lemme know if I got any of it wrong......
So what are the specs on that jeep now troy?
'97 SE 4.0/Auto/231
-Initially had a 3.5" RE Super Flex kit with RE drop brackets, Heavy Duty Track Bar & Bracket, ACOS and 2" shackles
-Now has 6" BIGoffroad rear leaf packs, 1" shackles and the ACOS turned up to level it out (not recommended and will be changed to 5.5" RE coils soon)
-RE sway bar discos
-35" Mickey Thompson MTZ's on 15x8 Street Lock wheels with 3" back spacing and matching spare.
-Rear D44 with 4:88's, Aussie locker, custom truss by Josh at Crawler Tech, TeraFlex disc brake kit and Superior alloy axle shafts.
-Front D30, 4:88's open and drilled/vented rotors.
-Currie Correct-link steering
-Advance Adaptors SYE and Tom Woods drive shaft
-TNT/Treks steering box reinforcement and M.O.R.E. steering brace
-Cat back exhaust system (custom with MagnaFlow muffler)
-Aftermarket exhaust header (APN?)
-Custom cold air intake (my design, utilizing the hole left behind by the snorkle) drawing air from a boat/marine aftermarket vent on the fender.
-Aftermarket aluminum valve cover and billet filler cap
-Battery Cables by 5-90
-Custom hood lifts (gas charged hatch-style cylinders)
-LeBaron hood vents
-Expanded steel (stainless) grille accents
-H4 headlights with BIGoffroad wiring harness
-Warn Rock Crawler front bumper
-Hella lights
-Smittybilt XRC8 winch with synthetic rope and billet hawse fairlead
-Bushwhacker fender flares
-AJ's rock rails welded to frame stiffeners installed by Josh at Crawler Tech
-Trail Tuff (old school!) rear bumper and tire carrier.
-Tomken gas skid
-Full window tint
-One helluva sound system (2 tweets, 4 5.5" mids, and a 12" sub and 2 amps)
-Prestige auto alarm with engine start/warm up.
-Realistic 40ch CB
-Pilar pod with Auto Meter oil pressure/trans temp gauges
-Custom rack system in the rear cargo area
-Upgraded stock buckets to a nice pair of "Classic" buckets
-Husky mud mat floor liners.
To be added soon:
-Rock Hard 4x4 cage with all options
-Custom DOM/Heim steering links
-WJ right and left high steer knuckles/spacers/calipers
-TNT/Treks D30 truss
-JKS Over Axle Bracket
-Custom track bar
-Custom LCA bracket skids
-Apalachian Armor t-case skid
-SpiderTrax 1.25" wheel spacers
-Rock lights
Future additions (funds permitting.....
-Tera Low 4:1 kit with 2-low
-D44 Powertrax no-slip locker
-Selectable D30 locker
-Quieter exhaust that exits through the right rear lower quarter and armored.
-Custom roof sliders with integrated light mounts.
Wheew!
