Side axle Q
  • Thread starter Thread starter Bill90XJ
  • Start date Start date
B
Bill90XJ
Guest
Hi folks I got a quick side axle question. Dana 35.
Will a non-clipped side axle fit a c-clipped axle?
I snapped off a c-clipped axle and got a non-clipped axle kicking around and was wondering if I could use the non-clipped rather than hunting down a c-clipped replacement.
Thanks, Bill90XJ
You need a c-clip axle to replace your busted c-clip axle. The non clip cannot go in since there would be no way to secure the axle into the housing. The c-clip holds in your axle, where as the non c-clip is held in the housing by 4 bolts at the drum brake.
I was figuring that I could pull the bearing of the shaft and remove the mounting plate. Then put the c-clip over the slot that is in the end of the non-clip axle. The slot in the end of the non-clip axle is what made me think that this could work.
Bill90XJ
Not sure if the slot on the non-clipped axle is same diameter and would match the clip. Even with pulling the bearings, im not sure if you could make the outer bearing work....If you had the axles side by side you might be able to get a better idea.... :confused:
