Sick Dog Racing Jeepspeed Build
thats a beautiful node in the center of your b pillar... you must be a patient man!
your cage shares a lot of design cue's with mine, that makes me feel better about my work!
Thanks
Patient....not me. 20 years ago we used to notch the tubing with a chop saw and hand grinder, that takes Patients. I dont know what I would do without my tube notcher.
Dropped the cage last night and welded all top tubes.
Cut holes on the floor and dropped the cage.
what notcher you run? i like my JD2 TN-01, but it needs a 2nd notcher to help on the more complex notches on shorter peices. im thinking the notchmaster.
how'd the b-pillar drop out? it doesnt look like it would have room to drop thru a hole, due to the diagonals. did this stuff have to come untacked?
Its a pro tools notcher.
Yea, all the B pillar tubes except 3 where removed to weld the top of the cage.
More work on the C pillar.
Started on the upper rear shock mounts.
Rear upper shock mounts done, just need welding.
Looks awesome! wanna sell the 5 car? haha
Thanks. The 5 car belongs to M&D, and it is bad ass. Waste of a perfectly good oval window though.
Question are those shocks tilted back a little to get 90 degree's at bump? Were getting ready to do this to a buddys jeep.
There completely Vertical at full droop and about 2-3 degrees leaning forward (towards engine)at full bump.
I bought a 97 4.0 motor from Jon Krellwitz it was out of Symanskies Jeepspeed that Jon parted out.
I got a good deal on it but the passenger side motor had been broken a few times. Looks like two of the four screws hole had broken screws stuck in them.
Took a while to get the screws out. Cleaned all the holes up and got 3/4" of clean good threads on all holes.
I Installed the Brown Dog engine brackets. They really fit great.
Because Some of the hole on the block where damaged I made a modification to the passanger side Brown Dog mount to use the two alternator screws as well as two other 5/16 screws on the block.
Started working on the engine cage.
