Sick Dog Racing Jeepspeed Build
Front bumper and engine cage.
More pictures of the front
Started tying in the bump stops.
WOW!!!! if you dont mind me asking how much is the cage costing you?
Let me gather up all my recipes and I'll let you know.
Will Jeepspeed rules allow you to completely replace that front crossmember?
seems like with all the work you've done so far it would be easy to replace that swiss cheese :D
JeepSpeed Rule Book Quote:
4.1.1.1 Stock body only. All body panels must retain original dimensions and material type (except front fenders, hood and fender flares). No internal body structure may be removed unless noted herein, except to allow passage of roll cage tube where the hole must be welded closed using material of the same thickness removed. The stock rear upper shock mount cross-member may be removed or modified for installation of under-floor fuel cell. Stock seams may be re-welded, and material added for strength.
You beef them up but cant remove them.
Rear Bumper
Man if my cage turns out half as nice I'll be stoked! Definatly some
good work on this excited to see it done
Thanks, I cant wait to see it done as well.
Tying the engine cage to the top shock mount.
I Also started plating the cage to the body.
