Brian93XJ
- St. Joseph, MI
I am consdiering ordering the Rubicon Express 3.5" lift for my XJ to step up from 2", but when I put the lift on there now on, I bought a full set of Rancho RS9000X shocks. They are only rated to 3" of lift. Would they still be ok? The other thing I was thinking was I would order bar pin eliminators for the front and rear to extend things and just press the bar pins out of them and put metal insert tubes in instead since the eliminators will buy me another .5" - .75" of clearance for the shocks. Or if I just slice the ends off of the bar pins can i slide a bolt through the middle of the shock then without buying new insert tubes? Any suggestions? I would like to avoid buying new shocks if I can. I really like the Ranchos.
