IndyXJ
Member #1314
- W.O.P.R. command
Ok, I am writing because I am seeking the cold truth and guidance of you who have been in my shoes before and
want to go down the right path. Albeit the right path can be the most expensive. First off, my current rig setup is this and in progress.
99XJ 8.25 and d30 still at 3.55 on 35" MTR's. 6" Full Traction long arm.
I KNOW I need to go to 4.56 (or higher with a diff axle).
Question-WOULD YOU LOCK A 8.25 and regear to 4.56 and obtain a rear disc conversion, be it junkyard, kit on net, etc....
***OR***
get an 8.8..., 9" or Dana 60? and what end gear ratio? This install would be done with an expert who has done gears, lockers before and I'll be there learning.He can weld, etc. I have a few bucks to get it done. End goal-discs, regeared and locked.
My wheeling is Badlands, Turkey Bay(in KY)Redbird(in In) and an occasional jaunt to Tellico(not the big obstacles). This is NOT my daily driver and willing to go a little wild with it.
Forgive me if this has been brought up way too many times before, but like I said, I'm here to learn and trust your opinions. Thanks... :lecture:
***OR***
