- Bourbonnais IL.
so the jeep has a big overheating issue. changed the water pump about a year ago,also changed the heater control valve, recently did some wiring to a switch so the e-fan will go on when i want. i have a thermostat(not yet installed), but since the hose coming off the stat is hot then that probably not the problem right?? both fans spin and at a normal rate so no sure on the fan clutch.
thinking it may be a radiator...if so is there anything "better" or after market you guys would suggest?
you know how it goes upgrade anything that brakes, right?
