Runs: General Information
Bent
"I'm not dead yet."
The person leading the run has final say. Period.
Rattlesnakes:
This is the season and they are active.
Be aware they do not always rattle a warning prior to striking
Avoid wandering into the brush.
During the heat of the day they rest in shady spots just about anywhere and it can be easy to unknowingly disturb them.
Mornings they may be out in the open sunning. They are active in the evenings and after dark.
SAFETY THIRD:
1. Roll bar or factory installed hard top.
2. Adequate attachment points front and rear, i.e. tow hooks, receiver, etc. Tow balls are not permitted. **
3. Tow strap or rope; without metal hooks (recommend rated at 2 times the vehicle weight).
4. Spare tire within close diameter of other tires
5. Jack capable of lifting your vehicle enough to change a tire; tools to change a tire.
6. First aid kit.
7. Fire extinguisher with gauge indicating good/full, appropriately stored.
8. Seat belts for all vehicle occupants.
9. Battery hold downs
10. Emergency brake, parking brake, line-lock or other redundant braking system.
11. Antennas not mounted to the center of the roof must be rigid or restrained in a manner to prevent injuries.
12. No consuming intoxicants while on the sanctioned run(s); no showing up for the run loaded.
** Easy/ sightseeing run(s) having only attachment points at one end is acceptable.
Recommendations:
1. Boots or sturdy shoes.
2. Hat and or sunscreen.
3. Flashlight(s) some runs will have mines for exploring at your own peril.
4a. Plenty of water or other nonalcoholic hydration.
4b. Snacks and lunch.
5. Folding chair(s).
6. Dress in layers.
7. Windbreaker – it’s supposed to be windy.
8. tools/spare parts.
Fixed it for you....lol
I did not receive a spamwich....don't you like me anymore?!
