LOLZ............ laughs now that I re read it I cant beilive I put "water" :anon: donno what I was smoking!! But back to those shocks. Yes the hydraulic fluid does expand but in many instances it foams due to small amounts of air that are trapped in the "sealed" chamber.GrimmJeeper said:do you know anything at all about suspension systems? cupping is caused by the tires bouncing on the road while they are spining. it is almost always caused by shock failure. RARELY it can be caused by a tire being out of balance but it would have to be way off, and it only occurs opposite of the unbalanced mass. it has nothing to do with tire pressure or bad ball joints.
what? hydo doenst mean water when referring to shocks, its short for hydraulic. as far as i know no companies put water in thier shocks. its either oil or some type of gas. shocks stiffen up due to heat. heat makes the oil in the shock expand and over pressurizes the shock, making it unable to transfer the fluid inside.
:confused1
As for the cupping............ run some more tires around that les schwab or go stab some little kid who touches yer jeep :skull1: or slaps your mom. Surely felon you know this from the work release program?
I know nothing about suspensions
Oh back on topic as to save Jasons thread!!!! and by the way this is my RC 4.5 lift :laugh2: :roflmao:
