pritty much.sdryde said:is it hard to do this, how do you go about this operation, I once saw somethig on this and they essentially grind the welds out, heat the "c" and rotate, then weld back into place. is this right ?
Gravel Maker said:The real key is trying to make them match.....exactly
sdryde said:the deal is I built a linked front end that produces 23 inches of travel and at full droop the pinion angle is out of control, so to be able to regain 4wd I need to change that angle so I can put in a drive shaft.... any ideas??
no kidding, I've heard King makes shocks with up to 30" of travel, lets see some pics of said 23" of travel.CRASH said:Where did you find 23" travel shocks, is what I'd like to know? I max my 1310 CV with 12" of travel, 5" up and 7" down.
Hell, most 1 million dollar, 2 wheel drive Trophy Trucks have about 24" of travel, so I'm really curious to see your setup.
I knew I just saw this ad where they list up to 30" stroke on the pot this am, I'm sure they are customish and cost a very pretty penny though.CRASH said:King lists only up to 18" travel, which is 30" compressed and 48" extended. :shocked: I'm sure with the proper application of $$$ you can have them build you a 23" travel shock. I'd guess 37" compressed and 60" extended! :shocked: :shocked:
cracker said:FWIW, Currie completely cuts off the knuckle with the axle tube inside, rotates them, and butt welds them back on at your new castor.
