foxwar71
- Foxboro, MA
Finally a working laptop and a couple pics to satisfy the needs of some.
Yanked the 60 out and took a weekend to throw 5.38's/lockright/Ten Factory chromos/ECGS flanges along with all new bearings and seals and such. Got all the brakes together and run some brake lines on the axle to a flex line up the UCA. Drilled and tapped the RS cover for the breather and I'll run the vent line up with the brakes.
Finally!! Paint!! Got some Rustoleum enamel paint and brushed it on everything underneth. Also did some of the body and the rear half of the inside.
Got the bumps and shocks and all the jazz in there. Tossed the front end all together. Finished up both crossmembers for exhaust and driveshaft clearance. Traction bar is all together, rear brakes are gunna split on the axle with a flex like the front.
Built the exhaust this weekend. Ordered a bunch of random junk I needed, got some header wrap and SS band clamps. Gunna wrap the exhaust where it gets close to the floor and outback near the gas tank, might do the whole thing if I have enough. Got all new cooling system stuff Im gunna toss on and hook the engine harness and stuff back up. Im getting Colin's 3row CSF this weekend too, then I can hopefully fire this thing back up.
