Purple
- Mississauga, Ontario, Canada
Does anyone know/have one installed? I own a 98 and it does not look as if it will be able to open full cause of the Heater vents.... any pics? im looking at a sony 7" units...
Root Moose said:I'm going with the motorized unit that digitalww.com sells. It's a 16:9, 800x480 (native) resolution panasonic in a third party housing. Includes touch screen for ~$500USD (IIRC).
I haven't ordered the unit yet, still dealing with software/sound (ALSA is friggen' annoying).
casm said:Hey, Moose - whatcha working on? Just curious as I suspect we're tackling similar projects right now.
casm said:OSS sucks tooUnder my list of annoyances in *nix, sound and printing are probably top of the pile. BTW, have you looked into JACK at all? I've been playing with it a little bit of late and although I'm still getting used to it, kinda like it - reminds me a lot of the server approach taken by BeOS to various components of the system.
Root Moose said:This is part of the direction where I am going:
These screen shots are quite dated. I've modified some of the look and feelie stuff since then.
For audio and such I'm using gqmpeg - it's heavily themeable as well so I can make it conform to what I want it to do.
The only part of the project which is keeping me from moving this from "proof of concept" to a working, installed prototype is the audio in Linux. ALSA is so poorly documented that trying to do anything with it is a major pain in the ass. Unfortunately I didn't do myself any favours by picking the Audigy 2 NX as my secondary sound device - it only recently reached a half decent level of support by ALSA.
In retrospect I kinda wished I had waited longer before bying the mainboard for this project (VIA EPIA M10k-N). If I had my time over again I probably would have gone with a Mini Mac running OS X without Aqua (i.e. OS X with X-Window on top as the environment).
The project has complicated sound requirements. The onboard VIA sound is used by the system level bleeps and blops, the USB FM tuner has an analog output that goes into the VIA mainboard, the VIA line out goes into the Audigy, the Audigy drives my car amp(s).
Still finallizing how to do the car level audio gear. I want to basically mimic the factory 4.0 sound but use the center channel driver on the Audigy to have the CB sound come up on the dash are only. This reads more complicated that it really is I suspect/hope.
We'll get there. I've got ALSA 1.0.9 installed outside of the kernel now, seems to be moving a little better.
casm said:Yeah, but it looks great. Seriously, I like the layout a lot. What's the 'CON' button for? Console? And what's the underlying window manager, or are you just using your own app instead of one?
casm said:I was using xmms in commandline mode with the intention of writing a plugin to get the audio display to where I wanted it, but kinda got stalled on that. I like the gqmpeg idea, though. Out of curiosity, are you planning on doing on-board MP3 storage or reading from an external device? Also, you wouldn't happen to know of any mini-ITX motherboards with onboard AM/FM tuners by any chance, would you? Or even PCI tuners small enough to fit that form factor with a riser card?
casm said:It may not be great, but I figured on just using onboard AC97 - it'll do 5.1 and is probably good enough for non-mobile-audiophile applications, plus is supported well and comes on every freaking compact motherboard out there.
casm said:Interesting idea. Hm, that's making me rethink the mini-ITX route.
casm said:OK, stupid question (and forgive me on this, since i'm not big into car stereo): why not just remove the Audigy from the equation altogether? Use the VIA's PC Speaker to do the system noises (just generate custom sounds for each event rather than the traditional PC beep, which should also allow you to mix over the playing audio) and send everything else out over the regular line out?
casm said:Sounds good; I look forward to seeing how it progresses. Hey, what's the underlying distribution? I'm using a very cut down Slackware on mine with the intention of going over to a kiosk-specific distro later (still undetermined), but am open to suggestions.
RichP said:I want to thank you two immensley, talk about solving a problem out of the blue that has been frustating me for several months and here I find it under a post that I have passed over several times as 'not of interest'... thankyou thankyou thankyou.... :kissyou: :kissyou: :kissyou:
casm said:BTW, Moose: one thing I had been looking at doing was ultimately making this a mini-distro with plugin capabilities. The idea was that there would be a basic feature set (MP3 player, AM/FM/TV tuner, GPS, 802.11) but precompiled binaries could be packaged a la pkgtool / dpkg / RPM and added as needed. An XML file would describe UI changes back to the screen parser, so everything could integrate back into the UI without any major changes to the OS itself; this XML file would also describe the locations of all installed / binary-created files in case later removal was necessary.
or something like that.mkcfg --first=NAV:gpsdrive --second=AUD:gqmpeg --third=WiF:kismet --fourth=:clock:date --fifth=:temp-degreesC --sixth:logo:moose.gif --navbar:left:120px
Root Moose said:The window manager is transparent from the "modules" (applications). Because fvwm is so powerful it can be used to "tame" poorly behaved applications that want to pop up windows where ever they want. Also, it has a very rich configuration file so it can be made to look pretty much like anything.
Under Gentoo, provided you have access to bandwidth, adding an apllication is just a command line away. I understand that apt-get/yum works similarly.
I like the idea of a XML and/or m4 approach to the fvwm configuration. I may look into that once I've got the interface a little more formalized.
There already is an m4 config file system for fvwm out there although I don't use it myself.
I'm really not big on having any form of TV/DVD system in the vehicle. Between legalities and distraction I think it is a bad idea. That being said, if someone wanted to use my method of displaying the apps to make that part of the config then all the more power to them.
Damn, what side of the crypt did you wake up on?Purple said:heh, whatever..... ANY PICS OF DVD SCREENS INSTALLED IN XJs? NO TOPIC STEALING, START YOUR OWN!
