SurplusFan98
- LA
Seems like vinegar is a pretty common approach, but I'd be cautious about it.
The low pH induced by putting vinegar in the water causes metals to become soluble in water. Metal erosion rates increase dramatically when dropping into this regime. Not a big deal for a thick steel block or head, but can be a problem for an aluminum radiator or heater core if the pH is below 4. You could purchase some pH strips and see
I'd be more inclined to use Thermocure perhaps altering with the Prestone product. Thermocure attacks rust without lowering pH while the Prestone product works more on scale.
Anyhow, if you are using the Prestone, I'm not sure you should be expecting the coolant to ever be clear or nearly clear at the end of an exposure cycle. It may take hundreds of hours of exposures and flushed before the water is clear at the end of a cycle.
Yep, you're probably correct. I'm still flushing this thing. Its improved to the point that the water doesn't go brown while I'm still filling it, but when I fill it and cycle it through for 10 minutes, its still basically southern sweet tea after the fact. Can't even tell you how many jugs of distilled water I've run through it at this point. Going to have to switch tactics. Will try some of what's suggested here.
