tkotitan
- Vermont, USA
(as an aside) I am getting tired of not being able to have a sig to state my XJ specs. If I am missing something in the control panel someone message me.
'94 XJ 5spd 4.0L 2dr SE. Chrysler axle.
So the 94 (I believe pre 96) has no raised floor for the front seat, making the transfer case sit a little lower underneat.
I am a bigger guy and have broken 2 Jeep seats before I got creative. Part of the problem was one stud was sinking through the floor with a little hole of rust punching through. This is due in part to having 3.07 gears on the 5 speed, it is so touchy and has so much gogogo that I break seats.
I said to myself the old Volvo seats were much tougher. There are no hinges for folding the seat, but a big crank wheel that is indestructible. I took the passenger seat out of an old Volvo 740 because it was in better shape than the drivers and welded the sucker in there. The problem is that the tranny takes up much more space in the XJ and I needed to raise the deck to fit the chair in there.
My mechanic had the idea - cut 2 pieces of C-channel and drill holes for the stock bolts. We did, and then welded the chair frame to that. It barely fit, and since I am tall if I am sitting up straight and hit a bump my head will bounce off the ceiling sometimes.
The nice thing about the c-channel trick is it covers any small floor holes and gives it a nice solid base.
Not sure if I recommend this again since like I said, it barely fit. But it is so much more comfortable. I cannot slide it back and forth because we had to weld it down. But I do have a million degrees of incline adjustment with the big crank. So yeah, no getting in the back from the driver's side, people have to use the passenger door which has the stock 2dr seat.
Annoyed today because the seat is starting to break, springs and internal attachments are making it shift more. Since I have the setup I may try another volvo seat since I know it fits in mine. At least I can take it out.
Any suggestions on a comfy alternative seat? Howabout on a budget?
