Runnin'OnEmpty
- Southeast USA
An ohmmeter reads resistance by sending a very small electrical current through the circuit. It sounds like this current is heating up the CPS coil and causing an open circuit. My guess is that the CPS is indeed bad. It should be able to hold the resistance reading indefinitely. Check the ohmmeter on something else, to make sure the trouble isn't in the meter.....
