cruiser54
- Prescott, Az
What brand did you get this time?
I'll do that. But would that cause sustained high idle??
MAT and CTS both check OK.
Yes to the FPR smell test for a gas leak.I'd smell fuel from the fpr when I disconnect the line if there was a leak, right?
Now that your pump is replaced, injectors are replaced (new?), and tps is set correctly why dont you pull your dist and index it properly. Or put the wires on correctly (I forget which it was you had done).
LOL, you mean like I did in the dark the other night, when I reinstalled the dizzy cap and rotor after inspecting when mine died, but I did not get the rotor seated down all the way?:doh:Or put the wires on correctly (I forget which it was you had done).
His number one wire comes from where 3 should be if I remember correctly.LOL, you mean like I did in the dark the other night, when I reinstalled the dizzy cap and rotor after inspecting when mine died, but I did not get the rotor seated down all the way?:doh:
Made the oddest cranking noise when it tried to fire, like I had lost the timing chain. Crank,Crank,Crank,Crank,Crank,Crank, THUNK!, ughhhh, Crank,Crank,Crank,Crank,
Rule number one, always recheck your work!!!
Nope. Not like that. For some reason my replacement distributer body rotates, whereas a normal one should not. my dad and I found TDC and got it timed right.
Chris is bringing up something that has never given me an issue in the two years since we did it.
Then just check that it has not "rotated" on its own?
